1 - 12 of 12 Posts
I ride an 03 anniversary lowrider, stock carbureted TC88, has about 65k on her. Suddenly developed a ticking or tapping noise that sounds like it's coming from the rear cylinder. Also at the same time the bike got louder and again it sounds like it's in the rear cylinder. It sounds as if someone had taken the baffle out of that pipe. That's the only way I can describe it. And also she's running like shit now. Does anyone have any ideas or suggestions or has experienced this before? I would really appreciate any input.
Mahalo
Check to see of pushrods are loose when at TDC.
If so, you may have a bad lifter roller bearing. Would cause same sound you describe.
Reactions: Smoketown$1
Cam tensioners ,65k at least check them.
Senior Flatulant
Welcome from PA!
As stated above ... Lifters and, tensioners especially, have been a problem with the earlier twin cam motors.
"Rocker-Lockers" are a good add-on too.
Cheers,
Smoketown
Discussion Starter #7
Thank you everyone for your input. Im thinking lifter. Im gonna start there and see what happens
If the tensioners were replaced 3 years ago the lifters should also have been replaced too. OP should check his receipts.
Mahalo
Rear exhaust gasket blew out maybe, problem matches the symptom.
Discussion Starter #9
Why should the lifters have been changed along with the chain tensioners? Never heard that one before. Am I missing something???
I just changed both exhaust seals yesterday. Sounds and runs the same.....
Like shit
Like shit
Standard procedure when servicing the cam chest and plate assembly. All parts that come in the service kit are supposed to be installed.
Now you've heard it !
Discussion Starter #11
Well all I got in my "service kit" was cam chain tensioner shoes. And yes now ive heard it but you're thre only one ive ever heard it from. Thanks for your input
That sounds like you got a different service kit than the ones I was getting. I was ordering the cam service install kits that didn't include the tensioners, they had to be purchased separate.
The cam install kits include everything: gaskets, lifters, bearings, gears, chains, etc., just no tensioners.
FYI, the MoCo made these kits available for warranty back in '99 - '00 when the cam bearings were failing.
1 - 12 of 12 Posts
