1 - 10 of 10 Posts
I took my 2011 Deluxe out for a cruise yesterday and discovered it will no longer start in gear. When I put it in neutral it will start. This bike has only 15K on it. Is this a big deal to fix? :eek Thanks, Jim
Did you change the levers? There is a little switch on the clutch side the lever should hit when pulled in. I had to fix mine.:)
The rubber boot covering the switch might be torn allowing moisture in. That killed my front brake light switch. There both very similar.
i don't know what year they started but if the kick stand is down.the bike will cut off when put in gear.
Isnt that a export model feature?
1 - 10 of 10 Posts
