Hi. Just got the bike and don't know how to turn on/use the passing lights. They are two smaller lights mounted each side of the headlight. Can someone please help out with how to turn on and use. Merry Christmas!
First off, welcome to the forum and Merry Christmas!
They should come on and stay on when you start the bike. Kind of like running lights. To activate the turn signals you just use your thumb to push the long horizontal button at the bottom of the controls. See pic below.
Hi. Thanks for your reply. Have tried every combo I could think of with the turn signals, hi-low headlight beam. Must be a problem with them as they don't come on under any circumstances. Merry Christmas!
They didn't come from the factory on your FXDL . Look for a toggle switch somewhere down by your horn mount or a black pushbutton on the clutch lever perch . Those are the most common locations for the passing lamp switches . Also passing lamps are usually wired to only come on when the headlight is on the low beam .
Thank you everyone for the help. It just seems like they are not working. Found the pushbutton mounted at the left lever assembly. When pushed does nothing.
Welcome from Washington State, hope you enjoy the site. I hope you get the issue worked out...:cheers
Related Threads
Harley Davidson Forums
posts
2M
members
115K
Since
2006
