21 - 27 of 27 Posts
I found this video online for a Harley (But NOT a Streetglide). I assume my bike has an alignment issue in the forks similar to the bike in the video. I didn't think it would be such a big for the dealer to resolve. Harley Factory Rep told me Street Glides cannot be aligned like this and they refuse any other repairs. Also, Harley Engineer (The guy who actually made the video) spent about a day with this bike. Measuring, photographing and riding.
I watched this YT video again, and once again paying close attention. Now I'm a bit confused as to why the Rep told you the SGS cannot be aligned like that??? The SGS has the same front end as does the Ultra. My Ultra mounts up the same as the Heritage, shown in the video... Unless some major change was done between the Rushmore and the M8 that i don't know about. The internals or guts of the forks differ, but how they mount.... IDK..
Edit: I agree with the guy in the video: Pumping the forks up and down is just furbulous exercise. I align the forks by loosening what he did, but with the wheel just elevated, then go nuts with a rubber mallet. Then drop the front back to earth while keeping everything upright with the jack. Then torque in sequence... Never had a problem with it. This is how i have aligned every set of forks i ever touched. I think it was called "Knocking the spring out of it" or something like that. One difference: I always keep both upper and lower Triple Tree pinch bolts tight on one side, while loosening the lower on one side, then reverse sides... So only one lower is loose at a time. I never loosen the upper unless making a height adjustment or removing the forks.
Discussion starter · #22 ·
If I bought this bike used, I would probably consider performing some type of alignment procedure, but this is a brand new bike with a factory warranty. I shouldn't have to put a wrench on it for stuff like this nor should I. The Harley Factory Rep indicated to me that he would NOT authorize or suggest that a Harley Tech attempt this type of alignment procedure like the guy in the video performed (Yes, I told them about this video at the time of my service as well) because then the bike would "NOT track down the road straight anymore." I don't know if that is true or that I agree with that. That's what he said.
Wow, if it won't track right with the front end being straight... That only leave the back end being out of track.. Back to a crooked rear axle... Geez!
Discussion starter · #24 ·
There is definitely a "crooked" something but whenever I would use that word with the Service Manager or the Harley Davidson Factory Rep, (But NOT with the Service Writers) I got a LOT of push back. They both contend that they "don't see what I'm seeing" and that "most of their other Streetglides" are just like this anyway".....And when they say that, it seems to me that they DO see what I'm seeing...I really appreciate your time and effort in replying to this.
I don't know about these latest generation of Harleys but i had a fork alignment issue with my '06 Nightrain. It was after i had the inverted forks replaced after minor mishap. I rode from California to Louisiana round trip and i had noticed my bike was leaning s bit to the right side. I thought maybe load distribution may have played as part or maybe the way i sat in the saddle. Nothing i did got rid of the lean. When i got back home in Cali , the tread was worn down on the right side of the front tire. Almost perfectly from the center of the tire all the way to the side wall. I was told at first that it was the fork oil level on the right fork was probably low meaning the seal was probably bad. Well that wasn't it. It turns out they had installed the forks without checking the alignment. The tubes we slightly askew in the triple trees. They fixed the alignment but never did replace my tire.
This is an older thread. But I always thought that the forks and fairing were misaligned on my 18' SGS. Turns out that it was my new glasses. My left eye has a bad stigmatism, so the lens in my glasses are different.
21 - 27 of 27 Posts
