Clarify something for us:
The title of this thread is No power to fuel pump.
How did you determine that there is no power to fuel pump?
Ok, I believe I went thru that in another comment on here. But, here we go.
Been working on this for about a 15 months so far. Had a flat, ended up with some scaring on the saddle bags. Decided to do some upgrades while I was waiting 3 months to get tires last year. Completely removed every piece of plastic and metal body work from the bike, sanded it down, fixed the nicks, dings and scratches, repainted everything. Changed out the OEM headers for a set of V&H Bagger Duals and Cobra Neighbor Haters.
Now, in the process of tearing things down, I removed the quick disconnect from the tank without disconnecting the fuel line from the pump first. I know, bad idea, didn't realize it at the time.
Replaced the damaged line, put the unit back in the tank after I painted it.
Put the tank, both fenders, inner fairing and most of the rear back together. Thought I'd start the bike before I got to far to make sure I hadn't missed anything.
Battery was dead. tried the tender overnight, didn't work. So used a standard car charger on slow charge.
after a few hours, bike fired right up. No problem.
Shut everything down, called it a day. Next weekend I'm back at it. Battery is dead. Ok, through a charger on it on slow charge. After a couple hours I noticed the battery was getting hot, as well as the ECM. Just incase I damaged the ECM, I ordered a ThrunderMax Tunner/ECM and installed it, but got same results even after loading a basic map. Disconnected, went and got a battery.
Now the bike turns over just fine, but won't start. Tried ether, bike runs, but dies when you stop putting ether in it.
Started checking plugs for power, found none at the connection under the dash, nor at the connection near the ECM. I've ohmed out the dash harness, it appears fine.
This is about the time I found out there is not only a P&A Relay, but Fuse as well. It was blown. Replaced it, it blew as soon as I turned on the kill switch with the ignition on. Per someone's suggestion, Pulled the Relay and fuse doesn't blow.
I've run a jumper between the battery and the Red wire, but even though bike will start on ether, it won't run on it's own. Same result with the White/Orange wire. This is with the relay pulled.
I did loosen the the sending unit/fuel pump assembly so I could visually see it and I don't see anything disconnected but haven't pulled it completely out of the tank yet.
Currently looking for a video or some other reference on how to remove that pump so I can maybe check it outside the tank.
I'm not a mechanic, but I do a decent job of it if I can find the information I need. I've been working on everything from Weedwackers to class 8 trucks since I was about 8.
