Then THAT may have something to do with the fuel pump not powering up. The Harley ECM and BCM are a married pair. I'm not familiar enough with the Thundermax ECM and how it marries up to the BCM.
Makes sense tho ! Steal a Harley, buy a Thundermax, put it in and off ya go. That ain't how it works, there's more to that process. The BCM and ECM have to marry before they function together.
Ok, well, that's not exactly how it went down. I had the problem with the OEM ECM. If you read the comments I'd made earlier, the bike started up just fine. I went back a week later, battery was dead. Used a battery charger, not a tender, on trickle charge. Battery and the ECM BOTH got hot. Battery was charged enough it cranked good, but wouldn't start. Bought a battery, put it in and same problem. With the ECM and Battery both getting as hot as they did and now it not starting, I thought I might have cooked the ECM.
I was wanting to add a tuner anyways, I saw ThunderMax made an ECM/Tuner and picked one up.
When I first plugged in the laptop to it after installing it, it did have me put in my VIN number. But, I didn't see any information in there as far as marrying the new ECM to the BCM.
Is there a way to do that?
