24.4 right
25.9 left
Make sure the boards are lubricated and move.
2012 Harley-Davidson FLSTC Heritage Softail Classic – USA Specifications/Technical Details
US MSRP Price: Vivid Black $17,349, Solids $17,734, Two-Tones $18,054, Custom Colors $18,224 USD
Dimensions
Length 94.5 in. (2400 mm)
Overall Width 37.6 in. (955 mm)
Overall Height 55.2 in. (1402 mm)
Seat Height:
– Laden2 25.5 in. (648 mm)
– Unladen 27.1 in. (688 mm)
Ground Clearance 5.1 in. (130 mm)
Rake (steering head) 31°
Fork Angle 31°
Trail 5.8 in. (147 mm)
Wheelbase 64.5 in. (1638 mm)
Tires (Dunlop[emoji2400] Harley-Davidson[emoji2400] Series, bias blackwall front and rear):
– Front – D402F MT90B16 72H
– Rear – D401 150/80B16 71H
Fuel Capacity 5.0 gal. (18.9 L) (warning light at approximately 1.0 gal.)
Oil Capacity (w/filter) 3.5 qts. (3.3 L)
Transmission Capacity 1.0 qt. (.95 L)
Primary Chain
Case Capacity 1.0 qt. (.95 L)
Weight:
– As Shipped 730 lbs. (331.0 kg)
– In Running Order 761 lbs. (345.0 kg)
– Gross Vehicle Weight Rating 1160 lbs. (526.0 kg)
– Gross Axle Weight Rating:
– Front 430 lbs. (195.0 kg)
– Rear 730 lbs. (331.0 kg)
Engine
Engine Air-cooled, Twin Cam 103BTM
Valves Pushrod-operated, overhead valves with hydraulic, self-adjusting lifters; two valves per cylinder
Bore x Stroke 3.875 in. x 4.38 in. (98.4 mm x 111.1 mm)
Displacement 103 cu. in. (1690 cc)
Compression Ratio 9.6:1
Fuel System3 Electronic Sequential Port Fuel Injection (ESPFI)
Air Cleaner Paper, washable
Lubrication System Pressurized, dry-sump
Drivetrain
Primary Drive Chain, 34/46 ratio
Final Drive Belt, 32/66 ratio
Clutch Multi-plate, wet
Transmission 6-Speed Cruise Drive[emoji2400]
Gear Ratios (overall): U.S.
– 1st 9.311
– 2nd 6.454
– 3rd 4.793
– 4th 3.882
– 5th 3.307
– 6th 2.79
Chassis
Frame Mild steel tubular frame; rectangular section backbone; stamped, cast, and forged junctions; forged fender supports; MIG welded
Swingarm Mild steel, round tube sections, forged junctions; MIG welded
Front Forks 41.3 mm telescopic, “beer can” covers
Rear Shocks Hidden, horizontal-mounted, coil-over
Wheels4 (Tubeless Chrome Aluminum Profile Laced option):
Steel Laced
– Front 16 in. x 3 in. (406 mm x 76 mm)
– Rear 16 in. x 3 in. (406 mm x 76 mm)
Brakes:
– Caliper Type 4-piston front and 2-piston rear
– Rotor Type (diameter x width): Patented, uniform expansion rotors
– Front 11.5 in. x .2 in. (292 mm x 5.1 mm)
– Rear 11.5 in. x .23 in. (292 mm x 5.8 mm)
– Anti-lock Braking System: Available
Suspension Travel:
– Front Wheel 5.1 in. (130 mm)
– Rear Wheel 4.3 in. (109 mm)
Performance
Engine Torque5 (per J1349):
– North America 96.9 ft. lbs. @ 3000 RPM (131 Nm @ 3000 RPM)
Lean Angle (per J1168):
– Right 24.4°
– Left 25.9°
Fuel Economy6 (EPA urban/highway test) 42 mpg (5.6 L/100 km)
COLOR OPTIONS
Solids
– Vivid Black
– Big Blue Pearl
– White Hot Pearl
Two-Tones
– Ember Red Sunglo/Merlot Sunglo
– Midnight Pearl/Brilliant Silver Pearl
Custom Colors
– Tequila Sunrise/H-D Orange
U.S. MSRP
Vivid Black $17,349
Solids $17,734
Two-Tones $18,054
Electric
Battery (per Battery Council International Rating)
Sealed, maintenance-free, 12V, 19-amp/hour, 270 cca
Charging Three-phase, 38-amp system (439W @ 13V, 2000 rpm, 489W max power @ 13V)
Starting 1.2 kW electric with solenoid shift starter motor engagement
Lights (as per country regulation):
– Headlamp (quartz halogen) 55-watt low beam, 60-watt high beam
– Tail/Stop Lights 8W/28W (5W/21W)
– Turn Signal Lights 28W (21W) self-canceling
– Indicator Lamps: High beam, front fender running lights, neutral, low oil pressure, turn signals, engine diagnostics, security system7
(optional), 6-speed, low fuel warnings
Warranty
Warranty8 24 months (unlimited mileage)
Service Interval9 First 1000 miles (1600 km), every 5000 miles (8000 km) thereafter
