I don't know what to tell you. The main outer primary gasket didn't leak but both the inspection cover and derby cover gasket leaked like crazy. Then I installed their seals and now that's leaking. I don't know what else to say about it seems odd that the James gaskets leaked, and as soon as I took them out and put HD gaskets on no leaks so that's why I'm replacing the James seals that are leaking right after I put them in with HD seals.
Who knows maybe I just got a bad set, but the time and money it costs to go back in and do it over I don't think I will be using James again. $30 for the outer primary gasket alone. I spent $65 at HD today for just the 2 seals the outer gasket and 1qt of fluid just to fix a bad seal.
Thanks for the tip on the jack shaft seal the main seal states "oil side " which is opposite of most seals and the new HD jack shaft seal is a double lip so it's a little confusing as to which side faces the primary
